I'm looking for an accelerometer. It must: have 3 Degrees of Freedom/axis Be sensitive in the +/- .25 g range (doesn't need to measure outside that range at all) be less than an inch in at least two out of three dimensions, less than three in the third. be less than $50 sample at ~50hz + be able to store data be able to connect to a computer I'd be really happy if it were less than half an inch came premade/involved no soldering were less than $20 Thanks y'all
Well, i don't have any real experience with "g" meters, but i am curious, whats your application. On that, this is what i found with the limited knowledge i have, hope it helps. Honeywell Test & Measurement - Accelerometers Accelerometer - Google Product Search
