Hello , i have nvidia geforce gts 250 graphic card whith hdmi output and a sony tv with hdmi input. When i connect my hdmi cable i get video successfully but i have no sound. My audio card is audigy se. In order to make my video card output audio from hdmi cable i have to connect spdif from audio card output to video card input ? and if so , can someone help me with the audigy se ??? which pins are the correct ? thanks my audio card -> http://us.store.creative.com/Creative-Sound-Blaster-Audigy-SE-PCI/M/B000LP0R3E.htm my graphic card - > http://www.nvidia.com/object/product_geforce_gts_250_us.html my tv - > http://www.sony.co.uk/product/t32-l-series/kdl-32l4000/tab/technicalspecs
The above sound doesn't have a internal SPDIF connector but your motherboard should! which motherboard is it? did you graphics card not come with the required cables (its the same cable that connects the DVD drive to the motherboard for sound e.g. http://www.amazon.co.uk/gp/product/B002TGDUQE)
yes i have a cable like this, but my main audio source is audigy se , it doesn't matter ? my motherboard is this http://www.gigabyte.com/products/product-page.aspx?pid=2960#sp
I think your just gonna have to use the onboard sound, since your sound card doesn't have a internal SPDIF connector (2-pin molex). I had a look around google but didn't find anything solid to suggest you could can use your sound cards external SPDIF coax out to the graphics card SPDIF. The only thing I've found is this thread which suggests its not possible.
so you suggest to connect the spdif out of the mainboard (its an rca jack) directly to tv hdmi audio input?
Nope, you should connect the S/PDIF Out from the motherboard to your graphics card with the wire that came with the GPU. I've attached an image with the SPDIF out highlighted on the motherboard (its the black one), your wire should connect to that and the other end to the graphics card, which should also have a similar connector. After that it might just start to work, otherwise its probably down to software configuration.
And what are we doing if mu onboard sound card is broken ? in specifications for that Creative audio card - http://www.newegg.co...N82E16829102003 there is S/PDIF but i havent got that kind of connector
