Cool case, large. I'm a believer in having separate chambers and direct airflow through the case. Simple, effective. Not to mention the case looks sleek as hell.
Yeah, its a monster, and an expensive one to, but its pretty cool. My only criticisms are the orientation of the optical drive bays, and the position of the power supply. I really think, especially on a case of its size, i would like the PSU to be on the bottom, and i worry about power cables reaching the mainboard as well as the HDDs. On that, the "hot swap" is really cool, but it doesn't look like it would work that well with the way the connections are laid out. On a final note, yes, i like the fact A LOT, that they keep everything separate, thats very cool. Basically expanding on what is done by Antec, and their P180/190.
