Cloning to a second hard drive.
Discussion in 'Storage Devices' started by DavidNW, Apr 10, 2006.
  1. DavidNW
    DavidNW Big Geek
    Yeah, thought so, Matt. I'll live with it!
    Cheers,
    Dave
    PS. I'm looking for a download of RAID (apparently I need RAID 1 in my case). Looked quiet a bit on the Net, but haven't found a link yet. I'll press on.
  2. megamaced
    megamaced Geek Geek Geek!
    That's what I said:
    RAID 1: Disk Mirroring/Dupexing Duplexing.
    RAID 0 is striping with no redundancy. It increases performance but doesn't provide any fault tolerance should a hard drive fail. Basically RAID 0 is pointless.
    Unfortunately that is normal, and here's why:
    1MB = 1,024KB
    Notice that 1MB does not equal 1,000KB.
    The hard drive manufacturers use the formula 1MB = 1,000KB when calculating the size of the hard drive. This calculation is obviously incorrect and the manufacturers are cheating us of those extra megabytes! :x:
    Operating Systems do use the correct calculation, so that's why you see your drive as 74.1GB and not the advertised size of 80GB
    Think about it:
    On every 1MB, you are losing 24KB. That doesn't sound like much. But when you have an 80GB hard drive, those missing Kilobytes soon add up!
  3. DavidNW
    DavidNW Big Geek
    Thanks, Megamaced.
    Great info once again, and thanks to everyone. I now have the CD-ROM, DVD RW and new HD running thanks to you all!! A good day's work!
    Best regards,
    Dave
  4. Matt555
    Matt555 iMod
    We're here to help, glad we could be of assistance.
    :good:
  5. DavidNW
    DavidNW Big Geek
    Cheers, Matt. :good:
    Great work!
  6. pelvis_3
    pelvis_3 HWF Member For Life
    I applaud your persistance in this problem.
    Not many people have the patience :cool:
  7. Karanislove
    It means we must be getting 24kb extra on every GB coz manufacturers are calculating less than original and computer detects the right one.
    I didnt get your logic clearly
  8. megamaced
    No Karanislove, it means we are losing 24KB on every MB.
    The manufacturers are simply ignoring (or disgarding) that extra 24KB
  9. Karanislove
    I can understand this point because evertime we buy a disc we recieve less space in it.
    Lets do some calculations,
    As per you say according to manufacturers
    1MB = 1000kb
    so I suppose you must be saying that 1GB = 1000MB = 1000000kb according to Manufacturers.
    Which makes 80,000,000kb = 80,000MB = 80GB
    But you said computer detects the right amount, so according to computer it has to be
    80GB = 81920MB (80*1024) = 83886080kb (81920*1024)
    So, according to computer it has to be 2GB approx more than the original disc space...
    I think I am somewhere wrong in caculations but can you plz give me correct calculations. I realy wants to know why do we get less space in Disks.
  10. beretta9m2f
    beretta9m2f Karate-Chop Action Gabe
    Your calculation's correct. The HD companies don't go by that calculation which is what the OS detects. The companies round 1024 to 1000. but still call 1000 a GB. So, if HD companies went by your and the OS's calculation they'd either have to supply more gigs to say its an 80 gig drive, OR say the truth its a 74.1 drive.
  11. DavidNW
    DavidNW Big Geek
    Yes, those lost GBs can really add up. My new HD is supposedly '80GB' but its 'Total Size' is 74.5GB (which is the correct, actual size of the disk). These manufacturors, eh!
    Just found a little tool that converts bytes into kilobytes, mega bytes and terabytes and thought it might be of some interest:
    www.t1shopper.com/cgi-bin/calculate.pl
    Dave.
  12. DavidNW
    DavidNW Big Geek
    PS. Can't seem to get the link to work in this forum window - not to au fait with inserting links. Maybe anyone interested can get to the site.
  13. DavidNW
    DavidNW Big Geek
    I think is is the correct link:
    http://t1shopper.com/tools/calculate
    Just tried it and it works!
    Dave
  14. DavidNW
    DavidNW Big Geek
    Just read the technical info on the calculator link about how manufacturers calculate HD capacity sizes - quiet interesting!
  15. megamaced
    That's pretty useful! Thanks for the link Dave
  16. Karanislove
    Thanks for the calculater David but my confusions still remains. How manufacturers are calculating? Why we get the less space than it has to be?
  17. Matt555
    Matt555 iMod
    Okay 80GB from a manufacturer is using 1000 bytes as a kilobyte.
    so:
    1MB = 1000 x 1000
    1GB = 1000 x 1000 x 1000
    80GB = 1000 x 1000 x 1000 x 80
    Which is 80,000,000,000
    So an 80GB hard drive from the manufacturer actually contains 80,000,000,000 bytes.
    The OS uses the calculations with 1024 byes = 1 kilobyte.
    so:
    1MB = 1024 x 1024
    1GB = 1024 x 1024 x 1024
    80GB = 1024 x 1024 x 1024 x 80
    So a true 80GB is 85,899,345,920 bytes.
    However the HDD only has 80,000,000,000 bytes meaning it has less space than the 80GB the manufacturer quotes.
    If the HDD has 74.5GB space (as the OS reads it) then:
    1024 x 1024 x 1024 x 74.5 is almost equal to 80,000,000,000 (actual answer is 79,993,765,890)
    Does that make it clearer?
  18. Karanislove
    Thanks Matt...... I've got my answer~!
  19. Matt555
    Matt555 iMod
    ^_^
    Good.
    Glad I could help, once it's laid out for you and it's smack bang in your face you can sometimes understand it better.
  20. DavidNW
    DavidNW Big Geek
    Yes, Matt, your calculations are absolutely correct, and based on my '80GB' drive, they work out precisely to the number of remaining bytes on my HD in 'My Computer.'
    Nicely explained formula, btw. Good illustrations on IDE cables, and now this -obviously a man that knows his stuff! :p
    Dave.
