Im working on a very old compaq presario that i have installed the linux os on. It boots up, it lets me log on, but then it gets locked up after 5 min of being on no matter if im trying to surf the web or not doing one thing. Please help, thanks. pentium 2 266 mhz 10Gb maxtor (replaced the origional) 32mb sdram
well i would be... but it dosen't matter what i try do do on it it always locks up after bout 5 min of being on. lol its getting a bit frustraiting.
i highly doubt it but it sounds like a sasser condition dont worry man high chance you dont have it i dont really have a clear answer but wait for other feedback, one of us will definately provide you an answer
It is, thats why he said you don't have it. It just sounds like a Sasser symptom. But uhhhh, this is just a shot in the dark but what distro/version of Linux are you using?
Sasser is a Windows virus... there are no known virii in the wild for Linux. Even if there was, infection would not be automatic; you'd have to infect yourself. You've been using Windows too long, man. As for the problem, since it's about the same interval of time between freeze-ups I'd say Linux was trying to utilize ACPI power-saving features of the laptop which were not properly implemented by the manufacturer. I bet that if you disable ACPI the lockups will disapear. Also, make sure power saving features are disabled in the BIOS as well. If that does indeed fix the lockups, I'd suggest recompiling your kernel with only the ACPI functions that your laptop can support properly. That way you get the best of both worlds. All the best, -AT
