Dear All, I have bought a new head set for my desktop pc. When i plugged the head set, it set started working. After removing the head set i connected the speaker line,i could not get sound. When i replug-in the head set, it works but when i remove the headset and put the speaker line, the same problem. My sound card is creative 5.1 and creative 4.1 speakers.I have reinstalled the drivers but i could not rectify the problem. Can any body assist me on this. Thanks Yogaraj
Hi Friend, It would be better if you discuss with tech support people according to your speaker problem. I am sure tech support people will guide you properly for solve your problems. Thanks, James
Hi there, Try this: Windows: Start-->Control panel-->Sound and Audio devices On the audio tab set the default playback device to your main soundcard (AC97/Audio-chip/add-on-adapter), etc. Your installed audio device must be present there. If not, reinstall audio device 2)Check if your micro (pink) and speaker (lime) jacks are really correct and fully inserted! They sometimes stuck. For test only you can use earphone instead of microphone for Line In. Standard micro in Line In will NOT work. Go to: Start Programs Accessories Entertainment or go to Volume Control; right click on loudspeaker icon in Task Tray Options Microphone Scroll down Check "Microphone" If the bar "Microphone" is available, the microphone is detected by Windows now go on (If not, Windows has a problem with your microphone) Just to check if your microphone is broken or bad, you can use your headphones instead. They really work! Which one L or R is microphone now, I think it's L Check "Advanced properties" Check Micro "Advanced" Open Check "20db boost" or "1.MIC boost" depending on language version Volume level can be left in any position. Mute microphone!!! 3. Check audio now on windows base. If it still failing, ill do what madison said. Good luck!
