Hello, I was wondering if anyone could recommend a good phone that comes along or is compatible with a headset. Holding on to the phone for long periods of time at home is straining on the neck. I did google some results, but the products were kind of pricey (Around USD $80+) Does anyone have any knowledge on this? P.s I think this is the best sub forum to post this because it's the closest I could find which is related to phones, I guess.
I'm not sure if this is exactly what you are looking for but it might be suitable. Plantronics S12 - Headset with amplifier: Amazon.co.uk: Electronics It's the Plantronic S12. Firstly, I'd recommend Plantronic as I've worked in many corporate call centres and they are the best around for this kind of thing. I think both the Plantronic S and T series are the most suitable for home/small office use (although it has been a while since I have looked into this). The S Series tends to be the cheaper of the two. Plantronic equipment is pricey but is also long lasting a decent quality. The only issue is, it doesn't come with a physical phone handset as well and I'm not sure if you can purchase them. It would be something to look into.
