hi i know its been a while since ive been on but i have a problem with a laptop im fixing it ran fine until windows xp was reinstalled and now it wont stop running slow although all the correct drivers are installed and sp2 and i have done various hardware checks. hope u can help Cheers Dave
Check how many processes are running and which one is eating lot of your system... And close all the unnecessory applications
hi thanks for youre reply buts it a fresh install of windows surly only the neccarcery precesses are running? cheer Dave
Did you install it from a recovery CD? Coz most of the times a recovery CD comes with lots of usless stuff.
I'm not quite sure what to suggest here...hmm maybe go though a windows update, there might be a update/fix which might help? I think quite possibly there might be driver compatibility issues? Then again it could be something very simple keep us updated dude.
