[Laptop] Network controller problem
Discussion in 'Networking and Computer Security' started by bertyball, Apr 2, 2008.
  1. bertyball
    bertyball Geek Trainee
    I had a problem with my wireless connection, so tried to install new drivers, but it couldn't find one, then i unstalled the device, restarted my pc, install new hardware, check for drivers on internet, but it couldn't find one.
    Ive tried to download the intell proset...., but on the istallation it says"couldnt find device"
    sow i can't istall my network controler, now i can't go one wireless networks again, what should i do?
  2. thomas234
    thomas234 Big Geek
    Have you checked to see if there is a wireless switch on the laptop? Mine has one on the front which turns off the wireless adapter.
  3. bertyball
    no, it hasen't. it looks like the laptop event hasen't a wireless thing, becaus,he can't find the device, sow i think i schould bring him to a shop to look at it.
  4. thomas234
    thomas234 Big Geek
    Yes it sounds like a hardware fault, so a shop would probably be your best bet, although I imagine it won't be cheap!
  5. bertyball
    i hope it isn't expesif, becaus its actually my mothers laptop, and i f*cked it up sow
    probarly i have to pay lolz
    but thx for your help
