Need A Wireless Internet Card
Discussion in 'General Hardware' started by dageniusjay, Oct 23, 2015.
  1. dageniusjay
    dageniusjay Geek Trainee
  2. Wicked Mystic
    Wicked Mystic Big Geek
  3. Ssfgrfv
    Ssfgrfv Geek Trainee
  4. dageniusjay
    And that card fits my computer? What would I look for if I wanted to look around for something cheaper, like I see the one suggested has "PCE-N" and "PCIE", is that what I'd look for to find ones that are for my computer? Or are they all the same? I don't know much about this stuff.
  5. Wicked Mystic
    Yes, it should fit (on computers, compatibility is NEVER 100%). PCE-N is just model of one card. PCIE (or PCI Express) is connector type. So you need PCI Express x1 compatible WLAN card. For 12 dollars, that Asus is quite cheap.
    Another choice from same shop http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=9048103&CatId=2688
    Not that much cheaper.
  6. dageniusjay
    Cool! Thank you so much!
