Need advice for laptop
Discussion in 'Mobile Technology' started by BhargavSushant, Feb 21, 2011.
  1. BhargavSushant
    BhargavSushant Geek Trainee
    HI all ,
    I need a laptop , but as we all know that laptops are very fragile and thus I want to buy
    a rugged one, like panasonic laptops, but when I looked up the hardware configuration
    i figured out following drawbacks.
    1. low RAM (I need 2 GB minimum)
    2. touchscreen is not supported by ubuntu (Linux is must in my machine)
    3. low HDD capacity and old too (min req. is 300 GB)
    4. installed processor is 1.2GHz but now a days i series processors are in market
    though dual core or core 2 duo is enough for my requirements but in future
    i may want to upgrade.
    5. all drivers aren't available.
    so please suggest me a toughbook with all of obove features + toughness to trade with cf 29.
    thank you
  2. softechnet
    softechnet Geek
  3. BhargavSushant
    can we assemble a laptop
  4. Hardware Planet UK
    Hardware Planet UK Geek Trainee
    no i will not suggest you to assemble the laptop as it will create problems time to time so buy a good genuine laptop
  5. allisonsmith
    allisonsmith Geek
    nope i wont suggest u to assemble a laptop
