Need help upgrading video card and PSU
Discussion in 'Video Cards, Displays and TV Tuners' started by trixr4kidsdawg, Aug 3, 2007.
  1. roy92
    roy92 CSS HAXOR
    the memory doesn't matter, as long as the video card you're getting supports the resolution of your monitor, you should be fine.
  2. trixr4kidsdawg
    trixr4kidsdawg Geek Trainee
    o ok cause my video card has 320mb of memory but it supports 2600x1500 resolution. So it will work on my 25inch LCD tv? Would any PSU with a 24 pin connector work in my computer(i have a MID-TOWER case) or do i have to check the size?
  3. roy92
    roy92 CSS HAXOR
    Yeah that will work (your card is a 8800GTS right?) and yes, as long as your PSU is an ATX power supply, it will fit.
  4. trixr4kidsdawg
    O ok thanx. Yea its a Xfx Geforce 8800 gts 320mb xxx.:)
  5. trixr4kidsdawg
    hey guys i got my psu and my video card there in my computer, but now when i put the computer in sleep mode and i wake it back up the monitor sais no video connection its like if the monitor stops reading the video card.
    What should i do to fix this?:(
  6. donkey42
    donkey42 plank
    move the mouse & check in the BIOS as to what wakes up your system, i think
  7. trixr4kidsdawg
    the computer wakes up just that the monitor doesnt when the computer wakes up.
  8. trixr4kidsdawg
    how can i connect my tv to my computer i tried using the s-video but i think im doing something wrong because it doesnt show anything on the tv.
  9. roy92
    roy92 CSS HAXOR
    try this:
    right-click on desktop -> properties -> settings: and select the tv monitor or extend your view to this monitor option.
    if that doesn't work, go to the nvidia control panel and select the advanced settings view and select "set up multiple displays" in the left side of the window. see if your tv appears on the list.
  10. trixr4kidsdawg
  11. trixr4kidsdawg
    ey roy how can i check at what tempature my video card is running?
  12. roy92
    roy92 CSS HAXOR
    sadly, nvidia has removed this feature from the new drivers, as you may have noticed, the control panel is different than what it was before. there is "ntune" but it don't recommend it because of the issues it has concerning stability and it is considered as "bloatware". Then there's speedfan, but you have to do some command line stuff to read nvidia gfx card. If you don't do it, it will read some ridiculously high temperature which will slightly shock you:eek: .
    the article on the command line is here and to download speedfan is here
    hope these help
  13. trixr4kidsdawg
    is it true that the 320mb version of the 8800 gts has lots of problems?
