Network Problem
Discussion in 'Networking and Computer Security' started by Waffle, Sep 19, 2004.
  1. Waffle
    Waffle Alpha Geek
    Ok recently got house wirelessly networked with a Netgear Modem and a Netgear Firewall.
    Two Novatech PCI cards in PC - one upstairs, one down.
    All working fine for two days, and then stops responding - cant access internet upstairs or down. Still connects but no websites open up.
    Unplugged router, waited 20 seconds to discharge bits etc, put it back in.
    Upstairs works fine. Downstairs, no go. Still connects, but hell if I can get it to work. Considering calling tech support, but thought I'd ask here first.
    Any ideas?
    Thanks.
  2. Sniper
    go to 192.168.0.1 and check that it appears in the attached devices section? oh and are you using the latest firmware for your router? which one is it?
  3. paulatreboot
    paulatreboot Geek Trainee
    after putting 192.168.0.1 log into router and check the pppoa or pppoe and other setting are correct, and what operating system have you got
  4. paulatreboot
    i go to novatech as well by the way
    Paul..................
  5. Big B
    Check and make sure you have the same protocols installed for each NIC. You need TCP/IP installed if you ever hope to access the 'net. If that's good, go ahead and ping 127.0.0.1 (loopback address).
