No Audio Device!
Discussion in 'Sound Cards and Speakers' started by FSM00, Jan 29, 2006.
  1. FSM00
    FSM00 Geek Trainee
    Hello, recently my computer has been formatted and windows reinstalled. After that everything is working properly except that no audio device is detected on my computer ( according to Control Panel Sounds And Audio Devices ). Since I have only a basic understanding of how works I am here asking for help.
    and by the way how do you know what soundcard does your computer have.
  2. megamaced
    megamaced Geek Geek Geek!
    What's the make and model of your computer?
  3. FSM00
    FSM00 Geek Trainee
    I have a hp pavilion a630n, intel pentium 4 processor, with windows xp. SP2
  4. megamaced
  5. FSM00
    FSM00 Geek Trainee
    I ran the update. but at the end an error stated that an inf file is not found. and the probelm is not solved
  6. FSM00
    FSM00 Geek Trainee
    To be more specific :
    Errror: Can't find Match Relatek HDaudio Inf File!
    followed by
    Warning:
    Realtek HD Audio driver Setup Failure
  7. FSM00
    FSM00 Geek Trainee
    I appreciate your help alot mgamaced.
    After the error appeared during the update, i went back to hp support and downloaded the original audio drivers, and then update it and now it is working properly.
  8. megamaced
    A happy ending :)
