PCMCIA HELP......:swear:
Discussion in 'Drivers and Firmware' started by GeordieBoy, Feb 18, 2006.
  1. GeordieBoy
    GeordieBoy Geek Trainee
    I know PCMCIA are supposed to be easy, plug them in and away it goes. Well I did that with my new 4 port USB 2.0 PCMCIA card. Connected a device to it and they dont work. It seems to detect the damn thing, but it does not put USB 2.0 drivers, even when I tell windows I will choose my own drivers. This is getting very frustrating................any1 offer nay advice for me. It is a sum vision 4 port USB 2.0 PCMCIA card. I am running a Compaq Presario 2100. HEEEEEEEEEELLLLLLLLLLLLLLLLLLLLLP!!!
  2. jogoz
    jogoz Geek Trainee
    1. check windows update.
    2. try to search for drivers in the card sites.
    3. re- install windows with the card pluged in.
