Hi all, Just got my new phone. a nokia 9500 communicator! very flash and cool... http://www.nokia.co.uk/nokia/0,,57363,00.html can't find which memory card I need, the handbook says MMC, but everyone else says RS MMC (reduced size) anyone have any ideas? Thanks all
hmm have you had a look at the memory card socket in the phone? maybe that will give you a clue, if the handbook says MMC then I'd go with that, although some RS-MMC cards come with an adapter to make them full-sized so you can use them in an MMC slot...
do you know the differance between the RS and normal MMC? if it is the length then it is not a problem, but if the width is different then it will not fit in the slot. Thanks
The width is exactly the same, the length is different http://www.sandisk.com/download/photos/OEMPhotos/rs_mmc/rs-mmc-fam-w-adap-v2.jpg that's the RS MMC cards, I have the 128MB version, with that silver metal part attached they are exactly the same sie as a normal MMC
