please help
Discussion in 'Drivers and Firmware' started by lufc, Nov 2, 2006.
  1. lufc
    lufc Geek Trainee
    hi every one heres a strange one when i plug in my kodak camera into my usb the pc finds the camera them the harware wizard starts up now i have the latest kodak software installed on the pc and i have the original disk now back to the hardware wizard whenit starts looking to load the software it allways comes up saying cannot find the drivers i have tried to look everywhare for the solution but to no avail please help thanks
  2. pelvis_3
    pelvis_3 HWF Member For Life
    That made absolutely no sense to me at all!
    Did you follow the camera's instructions?
  3. mut
    mut Geek Trainee
    Wow, a bit of punctuation may help us understand you a little better mate.
    From what I understood:
    try kodak's website for help and software
    You can probably download the software there.
    If you have the original disk though, just put that in and run it like you would any other disc. If the hardware wizard isnt working, leave it and use the CD.
  4. Karanislove
    Is there any software in that CD? Install that software....
    [ot]I am not sure but it could be like my Nokia6680 mobile...To make it working I have to install PC Suite software and after installing this software, PC detects and loads the drivers automatically for my phone..[/ot]
  5. zeus
    zeus out of date
    Maybe you need to use an .exe file on the disk to get the drivers.
    ie The disk installs the camera and not windows hardware wizard.
    Right click on your cd rom drive and click explore then have a look for an install file.
    Or when the box pops up looking for the driver it usually says the name of the driver its looking for. Direct the search through every folder on the disk until you find it.
