Post yer temps!
Discussion in 'Overclocking & Cooling' started by max12590, Dec 3, 2005.
  1. Willz
    Willz MiCrO$oFt $uK$ :D
    thats a bit too high lol.
    did you apply thermal paste?
    you might not of put the heatsink on properly, or maybe its just a faulty sensor.
  2. harakim
    harakim Big Geek
    i have a pentium 4 1,8ghz o/c to 2,7ghz
    cpu idle temp: 35
    cpu load temp: 38
    system idle temp: 30
    system load temp: 36
    What are the risks in overclocking the cpu? Do they only apply if the cpu overheats or is given too much voltage?
  3. computerboff
    computerboff Geek Trainee
    I applied some thermal paste
    so i am hoping that it is just a faulty sensor, as there is no lag or peformance changes, that i think woul be apparent if it was really 80 C
