Well I'm sure most of you are familiar PC Wizard 2005. I just recently tried out this software and found it very useful. However, I did find something that strikes me as alarming. Not sure if the software is at fault or if its really something with my PC. In the Voltage/Temperature/Fans section of pcw05... It's displaying my power/aux temperature as 128C/262F degrees. Now I dont know much about computer temperature but I know that 262F is pretty damn hot. So, is this normal or is my PSU on the verge of burning through the PC case and then the floor?
I think this msut be faulty, as you may not have temperature sensors for that, as i had a temperature recorded as 128c when using speedfan, and it was false as i did not have a temperature sensor for that, so this could be the case with your high temperature reading, becouse if it got that hot, i think you would be smelling smoke by now :\.
