Running 2 X Molex To 6pin Pci Coverters Safe?
Discussion in 'Power Supplies and UPS's' started by psicobra, Apr 1, 2016.
  1. psicobra
    psicobra Geek Trainee
    Hi guys I had a r9 270 gfx card which died I have replaced it with a r9 380 but this card requires 2x 6 pin pci-e power plugs. I have a win power 750W modular power supply. I lost the original 6pin pci-e modular cable so I have been using 1x molex to pcie converter with no problems but now I need to I believe the power supply is a dual rail not sure tho. so my question is it safe to run 2x 5 pin molex to pcie converters thanks.
    PSICOBRA
  2. Wicked Mystic
    Wicked Mystic Big Geek
    Probably that will run just fine.
  3. psicobra
    cheers mystic I think I have solved the problem any way my PSU has female molex connectors for the modular bit so I just ordered a molex male to female lead and I have the molex to 6 pin pci-e adapter so both pci-e leads will have independent feeds from the psu
    Wicked Mystic likes this.
