I have a little network of 2 pc's running win 2k pro and I wanna know how I can send a msg with it, I know its possible(etrust EZ antivirus always send a msg when u downloaded new signatures) I've tried some stuff in the command prompt with the command "net" but I cant find it Can anyone give me the command how to send this kind of msg: computername: example msg: test Also when I use a proxy server do u know if Etrust EZ antivirus checks the files that r going to my other pc ? And ow yea if u wanna share any kind of internet between networks use ppp share pro availible at http://www.pppindia.com/intl/pppshar/ it says its 30 day trial but I think I've been running it longer then that Its soooo easy program u just install and setup internet exployer too use the ip of the pc that has internet and the correct ports wich r in the readme I can even use k*zaa on both of my pc's using this
ok, sorry about the late reply, did a bit of search on the net and found that the command to send between computers is "net send" in dos even better I found these little programs which look cool and might be useful to you? http://www.rpland.net/netsend/ http://www.ariolic.com/ntpager/ http://www.ariolic.com/tinymess/ hope this helps!
nope its verry simple u just type the msg and the other pc get a popup with the msg from "pcname" I can get a screenshot later its like a interface for the "net send" command
