Side Panel Mod
Discussion in 'Cases, Modding and Gallery' started by roy92, Jan 18, 2007.
  1. roy92
    roy92 CSS HAXOR
    im planning on building a new comp, and im gonna get this case
    coolermaster RC-330 elite
    im going to put a window mod into the case, and im wondering whether a jig saw should do the trick, or do i need any other tools?
    thanks
  2. pelvis_3
    pelvis_3 HWF Member For Life
    You could use a jigsaw with a metal cutting attachment, but it would be a very rough cut and would require a fair bit of filing to smooth things out. Your best chance at getting a successful, clean and accurate cut would be with a Dremel cutting tool. Very precise cutting with minimal mess.
  3. max12590
    max12590 Masterful Geek
    I used a jigsaw for my window mod. It works fine if you use one of those window kits with the rubber gasket.
  4. SexiMexi9018
    SexiMexi9018 Geek Trainee
    Dremel tools are the way to go if ur looking for a nice cut, u could also use a jigsaw tho, it depends on how much finishing work u want to do to make it look good.
  5. roy92
    roy92 CSS HAXOR
    is the dremel easier to cut than a jigsaw?
  6. max12590
    Jig is faster, Dremel is easier.
  7. SexiMexi9018
    ya, but when this is something ur gonna be looking at a lot dremel is a better cut so faster does not matter
  8. roy92
    roy92 CSS HAXOR
    thanks y'all
