Not really about case modding but couldnt find anywhere else to put it I wanna have the silent cooler avalible to me now I can buy at my local store these manfacturs of coolers: Zalman(is a bit expensive so I'm prob not gonna buy it) Many Coolermaster coolers(got 1 right now it came with my mainboard) Thermaltake I think I'm might go for the Mini Super Orb of Thermaltake. Not verry many choices so if you a internetshop that with a verry silent cooler and isnt to expensive(not 40euro+) and it delivers in Holland, place it here plz
I wouldn't get that mini-super orb with that CPU if I were you. If they have something like a Volcano 6CU+ or Volcano 7+--this has an 80mm fan with adjustable speed, that would be ideal. The Orbs are more style than substance, and the Super-Mini isn't designed with that fast of CPU in mind. I would look into something that has a copper base for better heat transfer, which the Volcano 7+ has.
Ok they got that 1 and its for xp 2600+ I'm gonna buy that 1 Thx btw can I modify the speed in windows ?
