System Runs Fine But Sb_pwr Led On Solid.
Discussion in 'CPU, Motherboards and Memory' started by JoeyMartin1958, Aug 23, 2015.
  1. JoeyMartin1958
    JoeyMartin1958 Geek Trainee
    Hello all,
    So I recently had to replace my motherboard due to the old one dying and being out of warranty. I got the Asus z97 Gryphon mATX motherboard.
    Swapped out motherboard no problem but the SB_PWR led is on solid, not flashing but solid. I have no issues with my system, everything works great.
    I checked the manual for my motherboard and while it does mention literally all the other leds on the board (even the bios flashback one right next to this one) there is no mention of this led, aside form the initial overall diagram. I have included pictures of my system with the led on and a screenshot of the manual with the led labeled. I just want to know what the heck this is?! Any issue this is alerting me of or how to get the led to turn off? I will be re-doing my system later this year to a white color scheme and this green is seriously gonna ruin that. Plus I'd like to know if my system is at risk and trying to tell me something.
    Computer build:
    CPU: Intel Core i5-4670K 3.4GHz Quad-Core Processor
    Motherboard: Asus GRYPHON Z97 Micro ATX LGA1150 Motherboard
    RAM: G.Skill Snipter 8GB(2 x 4GB) DDR3 - 1600 Memory
    Storage: Kingston SSDNow V300 Series 60GB 2.5" Solid State Drive
    Storage: Kingston SSDNow V300 Series 120GB 2.5" Solid State Drive
    Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive
    Case: NZXT Phantom 530
    Graphics Card: EVGA GTX 780 03G-P4-2783-KR 3GB
    PSU: Cooler Master 600W 60+ Bronze Certified
    +ASUS DRW24F1ST DVD SATA SUPERMULTI Burner SERIAL ATA BLACK OEM Bulk Drive
    Thank you all so much for your help!!
    Pictures:
    https://drive.google.com/file/d/0B7igrsMuc2UVZjNidktiVWFTNXM/view?usp=sharing
    https://drive.google.com/file/d/0B7igrsMuc2UVeTVfdG1kTXg4dFE/view?usp=sharing
    https://drive.google.com/file/d/0B7igrsMuc2UVTmtLd3BNQ2lPN28/view?usp=sharing
    https://drive.google.com/file/d/0B7igrsMuc2UVN2VHN29VRXgwSFE/view?usp=sharing
  2. Wicked Mystic
    Wicked Mystic Big Geek
    SB_PWR likely means StandBy_Power. So it says that standby power is OK so most probably there is nothing wrong. If it's blinking, then you may have problem.
  3. Ghostman 1
    Ghostman 1 Mega Geek
    There should be two wires, try reversing the wires.. or just unplug it, but thats only if it is not your main power source..
