usb not recognized ? why ?
Discussion in 'Storage Devices' started by black water, Oct 1, 2013.
  1. black water
    black water Geek Trainee
    Hello friends..
    I have an Adata usb flash 32GB, and I use it carefully , but after two weeks since I bought it , I plugged in, I got a message tell me that usb not recognized, and nothing appear on My computer.
    what is the problem , and what the solution ?
    thank you.
  2. Wicked Mystic
    Wicked Mystic Big Geek
    Check disk management.
  3. conniegarrick
    conniegarrick Geek Trainee
    It might have got corrupted. After some time pen drives suddenly stops working.
    Computer Accessories
  4. pctestcardcom
    pctestcardcom Geek Trainee
    If we have unplug the USB disk last time without proper quit the USB connection from the computer, we may risk of loosing the USB drive partition and data.
    There are some nice flashdrive application on the internet to check the USB HDD free.
    I would also suggest we install the latest mobo chipset driver follow by a reboot, the connect the USB disk again.
    Most USB software driver issue can be corrected by the new chipset driver.
    Hope this helps.
    Bill
    Tech Mananger, WPTinc.
  5. telliegirl25
    telliegirl25 Geek Trainee
    There's a possibility that there is a problem with your Windows computer, USB port or maybe your drive is dead or is in malfunction.
