wireless keyboard and mouse help.
Discussion in 'Drivers and Firmware' started by scar895, Aug 24, 2007.
  1. scar895
    scar895 Geek Trainee
    I have a wireless inland keyboard and mouse but i have heard i need software to use them on my computer does anyone know of a place to get it?
  2. edijs
    edijs Programmer
    usually the manufacturer ships a dirver CD with the device; didn't your package include any driver CDs?
    if you bought this second hand, try to go to the manufacturers web site and see if you can find the drivers.
  3. Ghostman 1
    Ghostman 1 Mega Geek
    What make and model is it ? If you are using xp , then it might just set them up for you. Just make sure you have NEW batteries..
