I have two power supplies 1) CORSAIR 1000 2)COOLERMASTER 1200 Are the cables interchange able? Or can the cables from one be used with the other? Thank You in advance Thank You cube that is exactly what I meant.
When you mean interchangeable, do you mean pull out a cable from one PSU and install it in the next? If so, then yes you can do this.
