Hi all. Following on from an earlier thread where i did an Xp Pro rebuild for a friend. Now the problem is he never told me to back up his Outlook calendar details. I did however save all pst files in the Outlook folder. So my question is "How do i recover his Calendar entries and update his new Outlook profile to show them?" Again thanks in advance for any replies.
Recovery the calendar from Edb to pst software. You can recover only the calendar and appointments. https://edbmails.com
Outlook PST files can be converted to Office 365 with eSoftTools PST Recovery Software. This software allows you to quickly export data from ANSI and UNICODE PST files to your Office 365 account with this software. It has a user interface that is simple to use and navigate. It lets you import PST files into cloud-based email apps like Office 365, Gmail, Yahoo, and Outlook.com, as well as select an export folder, email attributes, and folder status. This application is straightforward to use and comprehend. It is suitable for both non-technical and technical users. You can try out the download link before you buy. For more information:- Repair Microsoft Outlook PST File
