On my Logitech Z-5500 Digital speakers, there is this connector that says above it coax, but the thing is, it looks just like a femal RCA connector i think, and it too looks like a femal rca connector on my dvd player, i need to use Coax to get 5.1 surround sound, so is this indeed coax or RCA, and what cable do i need to get, as i have looked for coax cabled, and the connectors on them look as tho they wont connect into the coac connector on my Soundtouch Control Centre on the Z-5500's and on DVD. Picture of back: http://img.photobucket.com/albums/v319/thehub/SDCC.jpg (coax connector at side of the orange connector)
if your asking, what is COAX, basically its used for TV aerials (to connect a TV to an aerial) i presume that standard TV aerial COAX will do, purchase however much you need from a DIY shop (they will also sell the connectors, with fitting instruction, dont worry v easy to fit)
i got some standard tv arial coax going into my TV tuner, and it wont fit that, the coax connector is on the right side of that orange connector in the picture i provided, the Coax connector looks like a regular RCA connector, you see it? next to the orange connector, its black and its for Audio, Audio Coax.
i've tried zooming in on the connector, although it says "coax" above it it looks a bit like either coax or phono, can try shinning a torch on the connector while you take the pic, i've tried altering tone and brighness an stuff but i cant see the connector clearly enough
Found this at toms hardware, more details pic: http://images.tomshardware.com/2004/11/30/logitech_z/logitech_z5500_5.jpg
clicked url n got this error: Internal Server Error The server encountered an internal error or misconfiguration and was unable to complete your request. Please contact the server administrator, [email protected] and inform them of the time the error occurred, and anything you might have done that may have caused the error. More information about this error may be available in the server error log. presume its cos i'm not a member, cant find how or where to join Edit: found it will let you know
No, uk site has a review of it, man your internet must suck pretty bad, and your computer must if you cant view images, anyway, i saved the image onto my pc, here it is:
I think you need this [link=http://images.google.com/images?svnum=10&hl=en&lr=&rls=GGLR%2CGGLR%3A2005-45%2CGGLR%3Aen&q=5.1+digital+coax+cables]Source[/link]
They are looking very expensive [link=http://www.vanns.com/shop/servlet/item/compare/751010613]Check This[/link] I Recon, take this name to your closest electrical shop and ask them about it or a print out of the picture will be a good idea.
[link=http://www.justechn.com/reviews/articles/2005/08/25/logitech_z-5500.php]This thing Explains everything about your speakers[/link]
Hmmm, is there loads of typed of didigtal coxial cable, or is it all the same with the same connectors? Also, thanks Karanislove, been looking for a decent review on the speakers for ages, that one you found is spot on
I was talking about "Monster Cable IDL100 2M" No Problem mighty, I am a searching freak...... Edit: Some better reivews by public and a website........... [link=http://www.theglobeandmail.com/servlet/story/RTGAM.20041202.gtlogi5500dec2/BNStory/Technology]1. Website[/link] [link=http://reviews.compusa.com/2795/736124/reviews.htm]2. Public[/link] You got the nice blow ass system......~!
glad you sorted it, just wish i'd been more help, but like i said glad you sorted it thanx karen EDIT sorry i meant karan
Lol thanks, the subwoofer is almost as big as my tv, i heard that its overkill if its placed in a corner, i havent yet tried it in a corner, it's sat right next to me on some poly, i will take some pictures of it all and post in gallary , i have had it turned 100% up, and the bass was really good at 1-2 out of 10!!, but at max volumes if you go over 4 or 5, you hear wierd sound from sub, coz its too much bass for the sub to handle, thats how powerfull it is Donkey, thanks for your help aswell, you gave me some usefull advise
i dont know where you got the idea that i gave you some good advise, cos i've looked and i dont think i offered any good advise
