DSL ping peak problems
Discussion in 'Networking and Computer Security' started by Shile, Dec 31, 2004.
  1. Shile
    Shile Geek Trainee
    I have dsl 768/128 .... and I USED to play online games such Americas Army...
    Before with ISDN 1 channel (64k) it was Ok....with 2 even better..
    I gained DSL..and I have strange DSL ping peak problem.
    First I have normal ping (cca 100-200) but suddenly in couple of minutes it raises to 2.000 - 3.000 ...
    I am using Kerio firewall, Avast Antivirus (On-Access)...I "clean" my comp with AdAware Pro and SpyBoot S&D.
    Is there a solution for my problem? or give me some hint to make this normal...
  2. ProcalX
    ProcalX all grown up
    First off i would remove your firewall and anti-virus, and install Sygate Personal Firewall & AVG 7.0 (Anti-Virus) you can find these in the Download Zone.
    If that does not work I would have your phone line that the DSL is using checked for any static - they can fix this their end (your provider).
    Before you try and other solutions, please note that a 100-200 Ping on a 768/128Kbps connection is incredibly high, you should easily be getting 20-50 Ping.
    Next i would phone your Internet Service Provider (ISP) and ask them about it on a technical basis, telling them what you have already done.
