Hello, i was just wondering is it possible to upgrade my graphics card from PNY Verto GeForce 8400 GS 256mb to ATI Radeon HD 5450 1gb i would appreciate any help ! Thanks You Very much!
I think the 8400gs came in both pci express and standard pci versions. So, it depends on your motherboard. what is the model number of your motherboard? or the model number of your computer?
can't find any definite info, but it looks like your motherboard has a AGP port and not a PCIexpress port, so if that indeed is the case then you cannot upgrade.
sorry i totaly droped the ball on this post. I am also unable to find any good information on this model. due to the age of the system my best guess is that it has one AGP slot and the rest are standard PCI. if you could upload a picture of the inside of your computer where all the expansion slots are we could know for sure.
It is totally depended whether you got PCI-Express slot or not , i myself upgraded my cpu from Intel chip set to Radeon HD 5450 .... If u can reply back and give information about your motherboard than i may help you buddy !! PARDON MY ENGLISH
