Having Headaches
Discussion in 'Suggestions and Feedback' started by Billius, Feb 9, 2022.
  1. Billius
    Billius Geek
    How often do you have headaches?
  2. AleksShamles
    AleksShamles Geek
    I definitely have a headache once a week. And it happens that the pills do not help.
  3. JoWee
    JoWee Geek
    Hello. Yes, I also had such a situation. In general, I struggled with migraines for a very long time. It's very hard when pills don't help. And then I decided that I should try another remedy. I read on the Internet that there are excellent supplements https://www.clevescene.com/clevelan...p-neurogan-overview-2022/Content?oid=38193032 that will help get rid of headaches, as well as normalize sleep. In general, I suggest you try CBD Gummies for Sleep which will help you avoid headaches.
