Hi, the audio ports in the front don't work because they're disconnected and I don't know how to connect them here's a picture to see if you can help me. My PC: AMD Athlon 64 X2, Asus M2N-MX SE Plus (http://img353.imageshack.us/img353/4701/mainboardhz2.jpg) The audio cables disconnected are: R-Out & R-Ret (On the same), L-Out & L-Ret (On the same), MIC-IN, MIC-POWER y GND. Any help would be very much appreciated.
Not all motherboards come with those built on them.. And that picture does not show much. There should be a USB hook up and a sound and mic.
I don't understand what you're saying, but the motherboar has a green pin panel on the bottom left (i think that's where the cables connect to) it's 5 pins horizontally and 2 verticals.
hi, the green panel is your audio header, check your motherboard manual and it will tell you exactly where to connect the cables on the pins, then your all good to go your front panel audio will work.
Ok, my manual was lost but after checking a while I found it online and it says where to put it. Thanks.
