You can use this new eSoftTools NSF to PST Converter Software that is a very helpful solution to easily make the conversion task of NSF File into PST. It never harms internal data of NSF file during the recovery and conversion process. It is one of the best tools that nicely restore all mailbox items from corrupt NSF file database and save them to PST, EML, MSG, EMLX, HTML, vCard, CSV, MBOX, and another file format. Visit here:- Move from Lotus Notes to Outlook
If you want to transfer your Lotus Notes mailboxes to Outlook, According to my personal experience, I would recommend using a third-party tool, NSF to PST converter, because it is a simple method that allows you to easily convert your NSF file to PST without interruption. If I may, I recommend that you try Softaken NSF to PST converter. It converts multiple NSF files to PST Outlook, EML, EMLX, MSG, and MBOX, among other things.
