eSoftTools Outlook PST Recovery Software is the most effective solution to fix Outlook problem 0X8004060C and other Outlook PST file issues. This program might be able to help you repair corrupt PST files and fix the 0x8004060C problem number in Outlook. You can instantly access your email, calendar, files, and notes with the Outlook PST Recovery Software. Both technical and non-technical persons will find this software easy to use and understand. This tool can split PST files into sizes ranging from 1 GB to 25 GB. PST data can be exported to Zimbra, MBOXes, EMLX, HTML, new Outlook PST, EMLX, and other file types and cloud-based email services. Users can export up to 25 items from each PST folder to all conversion formats with the free trial version of this program. For more info:- Repair Outlook Error 0X8004060C
There are basically two methods to fix Outlook error 0x8004060C. The first is the Manual approach and the second is the use of a professional solution. I would recommend you to go through this write-up here you will manual approach and a professionals solution( PST Recovery Tool) to fix Outlook error 0x8004060C
