The easiest way of resetting a HP printer is through the reset button present at the back of your router. Press and hold the reset button for 15 second and the printer will automatically reset. If you don’t have that option, let’s look at another way to reset HP printer. How to Reset HP printer through settings? · Go to the log in page and sign in as the administrator. · Click on menu and select reset factory settings. · No, click on reset firmware and select reset. · When you select reset, the printer will restart. · You can modify the settings accordingly. Read more:- how to factory reset hp printer
This is for specific models of HP printers, but I'd assume the steps are more or less the same: Turn the product off. Disconnect the power cable from the product for 30 seconds and then reconnect. Turn the product on while you press and hold the Resume button for 10-20 seconds. The Attention light turns on. Release the Resume button. The Attention and Ready lights cycle while the product restores factory defaults. from HP support website
