I just put together a new system using an ECS848P-A motherboard (BIOS ver.1.0)with a Pentium4 2.4Ghz processor, a westerndigital HDD, and a Creative PC-DVD Dxr2 CD-ROM, OS is Windows98.
On startup I receive this error: "While initializing device NDIS windows protection error occured. Your multi-function device (standard dual PCI IDE controller) has some child devices using 32-bit drivers and others using compatibility-mode drivers."
On restart in "safe mode" I see that the HDD and CD-ROM are in compatibility-mode. I cannot use the CD-ROM in windows "safe mode" to run the motherboard install disc and it will not run in dos mode. I attempted run the install disc from the HDD by copying the disc onto the HDD (including hidden files) but it would not initialize. It seems that I need to run the install disc to get the correct drivers, and need the correct drivers to run the install disc. Can someone discribe how to install IDE drivers manually in a dos or win98 "safemode" environment? Or is there another option I'm not thinking of?
Jay
Jay
