Motherboard Replacement Asus P8z68-v Lx
Discussion in 'CPU, Motherboards and Memory' started by enr00, Feb 22, 2017.
  1. enr00
    enr00 Geek Trainee
    Hello,
    I have reason to believe that my motherboard Asus P8Z68-V LX is faulty.
    The processor is an Intel i5-2500k (Sockel LGA1155), while I have the Nvidia Gforce GTX560.
    I bought and built the system in early 2012 and now the mainboard doesn't work all the time.
    As I don't need top-notch performance, I don't plan on buying a new mainboard, CPU, GPU and RAM but would indeed prefer replacing only the defectuous mainboard.
    However, I cannot find the same (or other P8Z68) mainboards for not too expensive in any of the better known online hardware shops.
    What would you suggest as a resolution to my problem?
  2. Wicked Mystic
    Wicked Mystic Big Geek
    I suggest you buy some other motherboard. LGA1155 boards are hard to find nowadays.
  3. enr00
    enr00 Geek Trainee
    But that means I also need to buy some new CPU, even though mine still works fine.
    Is that correct?
  4. Wicked Mystic
    I mean you should look for another LGA1155 motherboard than Asus P8Z68-V LX if that model is not available. Those LGA1155 motherboards are quite hard to find but there are some available. If you are not overclocking, selection is much better.
