Motherboard Voltage Level Question.
Discussion in 'CPU, Motherboards and Memory' started by LinuxUser, Mar 3, 2017.
  1. LinuxUser
    LinuxUser Geek Trainee
    Hello,
    This is my first post here and I'm looking for some advice.I've used a command to display voltage levels associated with an old motherboard,the type of which is probably irrelevant.I've noticed that a couple of levels seem too high and have "alarm" written after them.My question is what does it mean and what should I do about it?
    The output from the command is copied below.
    peter@peter-G31M-ES2L ~ $ sensors
    nouveau-pci-0100
    Adapter: PCI adapter
    temp1: +53.0°C (high = +95.0°C, hyst = +3.0°C)
    (crit = +115.0°C, hyst = +5.0°C)
    (emerg = +130.0°C, hyst = +10.0°C)
    coretemp-isa-0000
    Adapter: ISA adapter
    Core 0: +40.0°C (high = +76.0°C, crit = +100.0°C)
    Core 1: +40.0°C (high = +76.0°C, crit = +100.0°C)
    it8718-isa-0290
    in0: +1.12 V (min = +0.00 V, max = +4.08 V)
    in1: +1.89 V (min = +0.00 V, max = +4.08 V)
    in2: +3.33 V (min = +0.00 V, max = +4.08 V)
    +5V: +3.02 V (min = +0.00 V, max = +4.08 V)
    in4: +0.43 V (min = +0.00 V, max = +2.10 V)
    in5: +4.08 V (min = +0.00 V, max = +4.08 V) ALARM
    in6: +4.08 V (min = +0.00 V, max = +4.08 V) ALARM
    in7: +3.23 V (min = +0.00 V, max = +4.08 V)
    Vbat: +3.10 V
    fan1: 1035 RPM (min = 0 RPM)
    fan2: 2872 RPM (min = 0 RPM)
    temp1: -55.0°C (low = +127.0°C, high = +127.0°C) sensor = thermistor
    temp2: -2.0°C (low = +127.0°C, high = +127.0°C) sensor = thermistor
    temp3: +27.0°C (low = +127.0°C, high = +127.0°C) sensor = thermal diode
    cpu0_vid: +1.100 V
    intrusion0: ALARM
  2. Wicked Mystic
    Wicked Mystic Big Geek
    Probably nothing. Motherboard sensors are not reliable. Use multimeter if wanna be sure about voltages.
    Big B likes this.
  3. Big B
    Agreed. Motherboard sensors have never been that accurate. As Wicked said, a multimeter will be much better for readings.
