Need Help Picking Components For Diy Router!
Discussion in 'Networking and Computer Security' started by Torinaj, Dec 9, 2016.
  1. Torinaj
    Torinaj Geek Trainee
    Decided to do a pfSense based router. Will be using an AMD FX-4300 (95W). Motherboard will be either Asus M5A78L-M/USB3 or MSI 760GM-P21 (FX). Need help deciding between the boards.
  2. Wicked Mystic
    Wicked Mystic Big Geek
    Asus has 2 more SATA ports, (partial, not full speed) USB 3.0 support and DVI+HDMI connectors. Also Asus can support 125W FX CPU's. Those are major differences.
    At same price, I would take Asus. If MSI is enough for you and is cheaper, then it's your decision.
    Torinaj likes this.
  3. Torinaj
    Thanks for actually answering the question instead of proselytizing for Intel CPU! Much appreciated.
