Realtek RTL8211C where i can download this software because my laptop have no network driver. thanks for helping.
Have you unzipped it? if so, there should be file with the name nvunrm.exe just run that by double clicking on it. (I can't test it since I'm not on a windows pc)
i try it sir when i click it. it just show this http://i422.photobucket.com/albums/pp306/werf07/Untitled4.jpg
Right click on nvenetfd.inf and nvnetbus.inf one by one (not at the same time) and select "install". let me know how it goes.
i try sir. it say INF you selected does not support this method of installation? I don't know what i'm going to do this problem. i hope sir you can help me thanks for every thing.
On the desktop Right click "My computer" Click "Properties" Click the "Hardware" tab, Click "Device Manger" Expand "Network Adaptors" I assume here that; you will have a network adaptor listed which has an explanation mark next to it. Right click on it and select "update driver" On the next screen select "No, not at this time" On the next screen select "Install from a list or specific location (Advanced) On the next screen "click" the "don't search, I will choose the driver to install" Click "Next" Click "have disk" and browse to where you extracted the nvenetfd.inf and nvnetbus.inf files Pick one of them (try both) hopefully it should install the drivers, else you will get an error, saying something like "can't find hardware" which means we have the wrong drivers.
sir i try but still nothing, it said windows cannot load the device driver for this hardware.This driver maybe corrupt or missing.(code39)
Try these http://download.cnet.com/Realtek-RT...-2112_4-99235.html?tag=rb_content;contentMain http://drivers.softpedia.com/dyn-search.php?search_term=RTL82&x=0&y=0 http://www.brothersoft.com/realtek-rtl-and-fast-ethernet-driver-114357.html http://www.realtek.com.tw/downloads/
