Looking for suggestions for a dedicated ssd for windows files. PCIe SSD? https://www.amazon.com/gp/product/B01JCXXQ0Q/?tag=tec06d-20 OR SATA III? https://www.amazon.com/gp/product/B01LZ09A68/?tag=tec06d-20 PARTS 4 NEW Build: Windows 10 Pro Monitor: Dell 43" 4k Multi-Client Monitor (P4317Q) CASE: NZXT Phantom 820 Computer Case https://www.amazon.com/gp/product/B009QZH23S/?tag=tec06d-20 MOBO: ASUS ROG Crosshair VI Hero AMD Ryzen AM4 https://www.amazon.com/gp/product/B06W2L6GBX/?tag=tec06d-20 CPU: AMD Ryzen 7 1700 Processor (might go with 1800x for the extra 200mhz boost) https://www.amazon.com/gp/product/B06WP5YCX6/?tag=tec06d-20 RAM: Corsair Vengeance LPX 16GB (2x8GB) DDR4 DRAM 3200MHz https://www.amazon.com/gp/product/B0143UM4TC/?tag=tec06d-20 GPU: 2 GTX 960's (From old PC, planning on upgrading when a new series of nvidia gpu comes out) SSD: Plextor M8Pe 128GB HHHL PCIe NVMe Internal Solid-State Drive with Heatsink https://www.amazon.com/gp/product/B01JCXXQ0Q/?tag=tec06d-20 Storage: 1T WD Caviar Drive, 3T Seagate backup plus & 4T seagate personal external HDs PSU: (Already bought) CPU COOLER: Still deciding on a water cooler...suggestions are welcome.
Asrock Taichi is good choice for motherboard. Availability is somewhat poor but will get better. That site http://www.asrock.com/news/events/ContentCreation/index.html is mostly advertising BS. You don't need 1200W PSU, even 650W is more than enough. This SSD is better and cheaper https://www.amazon.com/Mushkin-REAC...1?s=electronics&ie=UTF8&qid=1492619090&sr=1-1 Everything else seems like OK.
Ryzen 7 1800x is really not worth it, 1700 can be boosted to 4 GHz, the same as 1800x, it only doesn't have automatic overclocking and has lower base frequency. 2 GTX 960 are really good, you should upgrade only if they are not enough for you. If I will buy new computer, I will save most money on case and buy some for 50 dollars, not for 200, but that's only my opinion.
