In our office we have 20 or so pc's. 1 is playing up, it cant print any pdf files, but it can print any others. i have checked other computers and they can print pdf's to the same printer fine, so it is not a printer problem. any help is apreciated, im fed up of google searching now ... Thanks, Jay.
Hi Jay Did you get anywhere with this? Maybe try opening the PDF with a different application e.g. http://www.foxitsoftware.com/pdf/reader/
You check your printer connection Ensure that the cable that connects your printer to your computer is securely plugged in. If your printer is plugged into a USB hub, then unplug the printer cable from the hub. Plug the printer cable directly in to a USB port on your computer. Ensure that your printer is turned on. If your printer was already on, turn it off. Wait 15 seconds, and then turn it on again. Try and print again. If your file still doesn't print, see step 10, "Restart your computer."
