Quiet hard drive
Discussion in 'Cases, Modding and Gallery' started by efx2003, Feb 15, 2005.
  1. efx2003
    efx2003 Big Geek
    I am buying a new computer case that does not have any type of rubber groment to quiet the hard drive. Is there a web site that sells rubber groment. Or is there something i can get to quiet my hard drive beside a hard drive enclosure. Please help if you can. Thank You
  2. Addis
    Addis The King
    No Vibes III is good, if rather large HD rubber thing.
  3. Dave35k
    Dave35k H4ck3r
    if your pc is un modded (no windows in the side) theres like a rubber mat that you put inside which generally quietens down the whole system in general. Hope this helps Dave :good:
  4. efx2003
    efx2003 Big Geek
    I will take a look at those items. Thanks for help.
