Ok you monitor gurus: I want to hang a number of monitors (LCD's...any size above 14") from a ceiling rack. They will be used to display server status info of my servers. 1. Does anyone know any grahic cards that will reverse a display image 180 degrees so I can display the images upside down? or another solution: 2. Does anyone know of any low cost LCD monitors that have a swivel that allows the stand to be reversed so the LCD monitor can be displayed right-side up when hanging from the ceiling? Thanks Medman
ATI radeon 128mb 9250 you can do that with the settings so i assume you can do it with higher cards but im no sure about lower
Almost any video card with 2d/3d support should be able to do it. The system I'm typing on now is an nforce 1 board and even it gives the capabilitiy to do Inverted Landscape 180 degree rotation.
Thanks to both of you. I was kind of looking for the "upside down monitor" solution so I wouldn't have to replace video cards :good:
All my video stuff is on the motherboard of my Dell servers. I have no idea whose circuitry it is. That's why I really don't want to go out and buy 6 video boards if I don't have to. I'll give a call into Dell and ask them but I don't expect any good news.
Before calling dell, right click my computer and go to manage, then go to device manager and expand the display adapters. It should tell you the video card there
