Total system lockup
Discussion in 'General Hardware' started by DaveUK, Jul 24, 2005.
  1. ThePenguinCometh
    ThePenguinCometh There is no escape
    Damn! Clicked on helpful button my mistake - again!
    Quite! I lost interest when it became a discussion on the benefits of various different RAM types which is not my forte, I didn't realise that the original problem had reappeared.
    Very interesting and well done on finding it. However are you sure it is the hard drive as it could possibly be the IDE cable, just an idea. Also did you have the master drive on the end of the cable and the slave in the middle? If it was the other way around then that may have been the trouble. If that was the case then I would try plugging the drives in as above and see if that makes a difference.
    Sorry if this seems all rather unnecessary and feel free to ignore me if you wish but I would be fascinated to find an error like that and would probably spend the next several days playing around with it until I'd found the exact problem.
  2. Anti-Trend
    Anti-Trend Nonconformist Geek Staff Member
    Fixed :)
  3. DaveUK
    DaveUK Geek Trainee
    agreed, I would love to get the bottom of this....
    I decided to change the IDE cable (as you mentioned) and I made sure that the master was at the top of the cable (I am sure it was before too). On reboot, I entered windows and found that Windows had decided to forget where the drivers for my NIC were. I reinstalled them, and as soon as the reinstalling completed, the pc froze.
    I rebooted and all is now fine and working. I'm going to blame the hard drive for the freeze still (since I had only just put the hard drive back in, and this is the first freeze I have had in a couple of days).
    However, this has made me start wondering something else. What would happen if my PSU was not powerful enough to power by PC? This is just a thought..I do have 2 x 80gb hard drives, a dvd drive, and a dvd-rw + a geforce fx 5600 ultra graphics card. My PSU is a "Antec SL350PGB 350W ATX P4 Smartpower Dual Fan Power Supply".
    Is 350W enough? and if it was not enough....could this be the cause of the freezes? I know this probably sounds like a n00b statement...but perhaps having the 2nd hard drive in too just maxes out the power too much?
  4. ThePenguinCometh
    Ah yes, all roads lead to the PSU. This thread will probably answer your PSU-related questions.
  5. DaveUK
    DaveUK Geek Trainee
    hmm i don't know - my psu isn't in that list, but Antec PSU's are well respected and known (i've read a few threads with people discussing them).
    Is there any way to test to find out if 350W is not enough power? I'm sure the quality of the PSU is fine, but I am worried 350 is too low for my system.
  6. DaveUK
    DaveUK Geek Trainee
    Anyone? :)
    I have also swopped out the "bad" hard drive for a spare 40gb one I had in another machine...so hopefully this will confirm whether or not the hard drive was the root cause of the problem, or something relating to having a second hard drive in there (ide controller?, psu?, ide cable? etc).
    Since swopping out the "bad" hard drive and going down to 1 drive, I haven't frozen at all...so it was certainly causing the freezes somehow!
  7. pelvis_3
    pelvis_3 HWF Member For Life
    "Basically" a 350W is enough to power mobo,GPU like a GeForce 5600 or something, 2 optical drives, couple of fans and i would imagine two HDD's. Your probably running that PSU to the limit! Id recommend a 450W, thatll do the job nicely.
  8. Matt555
    Matt555 iMod
    If you want to calculate your power usage, try this website http://www.jscustompcs.com/power_supply/
    Choose your CPU from the bottom of the page and then carry on from there, should give you some idea of what power you could be using.
    DaveUK likes this.
  9. DaveUK
    DaveUK Geek Trainee
    Thanks for the link :) I did their test and it says that I should use a minimum of a 307w PSU. I guess I must be pretty close to maxed out....but I did only just get this PSU :|
  10. Matt555
    Matt555 iMod
    glad i could help :)
