Hi, My Problem is like below. I have a computer and it has a seperate VGA card with DVI port and normal VGA port. The DVI port connected to A. I need to connect VGA port to B & C. In this case A & B are 22" and the C is 15" A & B should be Extended displays and B & C should be Cloned. I was able to connect A & B with extended only problem I have in C Can I do it? if yes what part need to connect pc-B-C? Thank you
