Resonance456
Geek Trainee
Hi all, I have 2 questions which I would very much like answering.
1) I want to buy the 7600gt @ 256mb (agp), and its most likely I'll have to get it online for about £106... however, i thought i would go to the pc stores and see what I could get there - it seems that no one is selling the nvidia 7600gt for agp, onlty yhe 7600gs @ 256mb or 512mb.
Now, what I was wandering is, what is the difference between the 2, and how big the difference is?? if there is a big diff between the 2, i will spend the extra to get the 7600gt, however, if there is little or no diff i will have to opt for the 7600gs - i am planing to buy these very soon, so any detailed information is much appreciated.
2) i want to get an xbox360 and since i do not have an hdtv i would like to play it through my lcd pc monitor. me and my frends have had lengthy debates on how this would work - some say i will need a hub like box to connect the 360 to, and then to the monitor, while others say if i get the right cables i can connect straight to the monitor, and some say i can connect it through my pc.
I was just wandering if anyone knew how i would go about this?
THANKS very much to any help received :D
