-50C Running Temp
Discussion in 'Overclocking & Cooling' started by Goliath666, Aug 24, 2006.
  1. Goliath666
    Goliath666 Geek Trainee
    this video shows a tutorial on setting up ur CPU to runn at way under freezing temp. how did they doo that
    Cooling With Compressor Video
  2. Matt555
    Matt555 iMod
    That probably uses Phase Change / Peltier (sp?) cooling. It's an extreme way of cooling components (CPU's mainly).
  3. Big B
    It'd have to be phase change or liquid nitrogen. Peltier does a good job for sub-ambient temps, but it's not enough to get close to running subzero numbers.
  4. Goliath666
    here a Liquid Nitrogen cooling and the above post doesnt look anything like it.
    i wanna how i can try to do the above post
    Overclocking To 5Ghz Video
  5. max12590
    max12590 Masterful Geek
    It is the Prometia 2 Phase Change. It is the exact same system that goes into a refridgerator or air conditioner. Unfortunately, they are mighty expensive.
