A problem with my NIC (I think)
Discussion in 'Networking and Computer Security' started by Initiator, Jul 31, 2009.
  1. Initiator
    Initiator Geek Trainee
    I have a problem, probably with my NIC.
    In general, the problem is that I DC from the Internet about every 1 sec to 5 min.
    A little more in-depth:
    I've got an ISR with 3 PCs connected through Ethernet. (Cable)
    Now, Only 1 PC have this problem.
    The ISR is constantly connected to the ISP and my connection to the ISR is intercepted.
    I have no idea why that happens but i have a few ways to reconnect:
    1. Restart the PC - works 1/2 of the times.
    2. Disable & then Enable The NIC - works 1/2 of the times.
    3. Repair the NIC using Microsoft Repair function - works 1/10 of times.
    Symptom Description:
    Some times, the PC is DC-ed (disconnected) from the ISR as soon as my PC is up & running.
    sometimes the PC is DC-ed after 1 or 2 minutes.
    And VERY rarely it takes 30 minutes till the DC..
    I'm really tired of this, any 1 knows what might possibly be reason for that DC problem?
    Thanks in advance.
    DC - Disconnect
    NIC - Network Interface Card
    ISR - Integrated Services Router
    ISP - Internet Service Provider
    Edit: Oh, By the way, The Connection is ICMP Flooded as well.
  2. donkey42
    donkey42 plank
    assuming you've tested stuff like cables and reseated NIC tbh you are best starting to test your firewall & possibly move system to DMZ if you have one
    test your firewall with some free / shareware here
    if your firewall checks out ok, perhaps a new NIC may be the answer
    BTW: what OS on misbehaving system ?
  3. Initiator
    Well.. the OS was XP Pro SP3 but while tring to fix the prob, my HDD died so i needed to buy a new one (Drive C was the one to die). so I needed to install a new OS, so I'm trying the Win7RC at the moment..
    I'll post ere again if the prob is not solved. if i'll figur it out i'll post as well..
    10x.
